Автор Тема: QRP SDR трансивер M0NKA mcHF  (Прочитано 37149 раз)
Re: QRP SDR трансивер M0NKA mcHF
« Ответ #90 : Декабрь 01, 2018, 01:23:36 am »
внутри AS5040
Пришла зима - время паять. Валкодер поменять что-ли...
там JMN еще хотел
может скооперируетесь
платки я вам выделю
« Ответ #91 : Декабрь 01, 2018, 09:52:12 am »
Отлично!
« Ответ #92 : Декабрь 03, 2018, 08:42:58 pm »
Немцы разошлись:
Added manual trigger for Twinpeaks correction
This is a debug function, should not be needed normally.
Refactoring of AGC WDSP and FM (De)Mod
- extracted all configuration AGC WDSP configuration parameters into
  extra structure agc_wdsp_conf
- renamed structure holding fm configuration values to fm_conf
- Fixed uninitialized value for phasedOutput in si5351a oscillator code
  if #TEST_QUADRATURE was not defined
Refactored IQ Correction
- removed unnecessary counter (we always have more than 7 samples)
- added new state to indicate failed twinpeaks auto correction
- changed IQ auto correction default to be enabled by default active
  a new machine
- Added system info menu entry for Twinpeaks
Refactoring Audio Driver, mostly SAM, also small RTTY fix
- Tried to identify obsolete code and mark it appropriately
- Removed unused variables from global data structures
- Reorganized data structures for SAM & AM demod to be more encapsulated.
- Fixed tx marker on spectrum not changing when the RTTY shift was changed
