Радио => УКВ техника => Тема начата: admin от Мая 07, 2014, 05:23:08 pm
(http://www.amateurradio.com/wp-content/uploads/2014/03/wouxun-kg-uv8d.jpg)
Get ready for the next big thing in handheld transceivers, the Wouxun KG-UV8D! This dual band, dual frequency UHF/VHF two way radio upgrades the popular KG-UV6D with more powerful features at an even more affordable price!
The KG-UV8D operates on 4 watts UHF and 5 watts VHF. It features a whopping 999 programmable memory channels with DTMF encode/decode and high or low selectable power options.
The KG-UV8D also has duplex cross-band repeat capability, so you can operate your handheld in full cross-band mode! Transmit on one band while you receive on the other simultaneously. You can also receive two signals at the same time on the same band!
But the best features aren't just inside the radio. Wouxun has given the the KG UV8D a face that is as functional as it is cosmetically pleasing. The LCD screen is large, colorful and bright, with room to display all the information needed to operate the radio on both bands in any mode! The Power-On display is also customizable and voice prompts assist you with menu navigation.
The KG-UV8D is loaded with features! Channel Name edit and display, Dual Standby, 76-108Mhz FM radio, DTMF encoding, SOS function, low voltage voice prompt, VOX (Voice Operated Transmit) for hands-free operation and a high illumination flashlight are all standard on this radio. It even has a stopwatch!
The KG UV8D is powered by 7.4v 1700mAh (12.58Wh) Li-Ion battery pack for maximum uptime during operation. Power Saver Mode helps increase efficiency and preserve battery life.
Wouxun KG-UV8D Features
999 Memory Channels
Dual Band
136-174MHz VHF Frequencies
400-480MHz UHF Frequencies
Repeater Capable
Cross-Band Repeat
4W/5W Transmit Power
Li-Ion Battery Pack
Rechargeable Battery Included
Battery Charger
FM Radio
SOS Feature
Memory Channel
Channel Scan
Priority Scan
Dual Watch
Dual Receive
Duplex Work Mode
Reverse Frequency Function
CTCSS/DCS Tones
CTCSS/DCS Tone Scan
Large Color Backlit LCD Display
Channel Name Edit and Display
Battery Meter
Low Battery Alert
Power Saver
Timeout Timer
VOX
Keypad Lock
Voice Prompts
Drop-In Charge Capable
Audio Accessory Connector
Cloning Capable
PC Programmable (Requires Optional Cable)
LED Flashlight
Stopwatch
DTMF Code
Reset
One Year Manufacturer Warranty
http://www.youtube.com/watch?v=6rqvSSbWjW8
