Автор Тема: Portugal Day Contest  (Прочитано 3037 раз)
« : Июня 13, 2020, 08:54:58 am »
Date:
June 13 and 14, 2020
Time:
12:00 UTC to 12:00 UTC
Bands:
10, 15, 20, 40 and 80 meter bands, fully respecting licensing rules of each country. Observance of established band plans is strongly encouraged.
Mode:
SSB, CW or Mixed
Category:
Single Operator all bands
Multi Single all bands.
Multi Multi all bands, 1 transceiver per band.
Exchange:
DX Stations send RST followed by one sequential number beginning 001.
Portuguese Stations (including Autonomous Regions of Azores and Madeira Islands) send RST followed by letters identifying their respective District (or County if Azores and Madeira Islands) – check list bellow.
QSO Points:
Contact between DX and Portuguese Stations are worth 10 points (DX/CT scores 10 points and CT/DX scores 1 point)
Contact between DX stations in the same Continent and Country are worth 1 point
Contact between DX stations from different Continents are worth 2 points
Contact between Portuguese Stations are worth 5 points
Scoring examples - CT side and DX side - Click Here!
Multipliers:
Each District (Portugal)
Each County (Azores and Madeira Islands)
Each DXCC entity
Multiplier Points:
Each Contact with Portuguese District (or County if Azores/Madeira) are worth 5 points
Each contact with a different DXCC entity are worth 1 point
Each multiplier is counted only once by Band regardless of the Mode.
Final Score:
Total contact points from all bands multiplied by the total Multiplier points.
Trophies:
->Click to view the list of Sponsored Plaques!<-
Plaque for the best World Score, with a minimum of 200 QSOs.
Plaque for the best CT Score, with a minimum of 125 QSOs.
Certificate for the best score in each DXCC country, if the total submitted score is higher or equal to 20% of the Worlds' best Score in each category.
Participation Certificate for all stations with 75 or more QSOs (Certificates will be available to download from the official Portugal Day Contest web page).
Prizes are not cumulative.
Logs:
Logs should be organized following Cabrillo file format.
Deadline
All entries must be emailed or postmarked no later than 1st July of the same year to:
e-mail to rep-concursos@rep.pt
The Cabrillo log should be attached as a file, with your callsign in the "Subject:" line of the e-mail.
Prefixes:
Portugal - CQ0 CQ7 CR5 CR6 CR7 CS1 CS2 CS5 CS7 CT1 CT2 CT4 CT5 CT6 CT7
Açores - CQ8 CU1 CU2 CU3 CU4 CU5 CU6 CU7 CU8 CU9 CR1 CR2 CR8 CS4 CS8 CT8
Madeira - CQ2 CQ3 CQ9 CR3 CR9 CS3 CS9 CT3 CT9
http://portugaldaycontest.rep.pt/rules.php
Re: Portugal Day Contest
« Ответ #1 : Июня 13, 2021, 03:22:51 pm »
Снова не услышал ни одной станции в этом тесте, но европа весело колбасилась в GACW WWSA CW DX, где и я пару часов...
